How to install Camper Webcam?
Hi good morning,
To use your web cam, you must first Install the software of your web cam.
To test your web cam go to yahoo messenger >>> Log-in >> your account. At the top of yahoo messenger >>> click and find MY WEB CAM and it'll work.
Thank you. Hope you can do it.
Regards.
Shenna22
Hi Anonymous,
If your web cam has a USB connection, then when you plug it into your computer the software will download. Once the software installs it will be ready for use. The USB cord will plug into one of the USB connection ports that is located on the side or front of your computer, depending on if it is a desktop or laptop.
If there is a CD that comes with the web cam, then you will need to put the CD in the CD-Rom. If your computer is set for Auto-play then the CD will instantly start the setup process of the software. To enable Auto-play, follow these steps:
Follow these steps:
To use your web cam, you first install the software of your web cam.
Insert web cam CD into CD room.
Find the model or icon name of web cam.
Install then click next>>next and finish.
Remove CD from the CD- room.
To test your web cam go to Yahoo Messenger >> log in your account. At the top of Yahoo Messenger >> click and find my web cam and it will work.
I hope can do it.
Thanks
