Mia Molly
20 points
Posted on - 05/28/2013
I recently created a new account on Myspace, I went through building up my profile, I found it’s good looking and easy website to use but the only thing I miss is adding tracks to Myspace, that I still can’t find in the music area where and how to upload audio tracks and I want to know what the properties of tracks I can upload in my profile (for example: what type and what size the tracks should be)?
I want to know the method of adding tracks to Myspace
Hi Mia Molly,
I'm using MySpace for a long time now. You can not upload songs on MySpace if you do not have "MySpace artist page". MySpace is on its way to try to regulate that you can not upload a song if you are not the real owner of this song.
Maximal size of mp3 file can be up to 10 MB.
Once in your MySpace page, click on the music link. This link will direct you to MySpace music area. Here, you will find a drop-down box search menus which you will use to find the right background music that you want. Choose the artist picture or name you are looking for in the search results. You will see a gray box which contains music at the artist's MySpace profile. To add the artist's song to profile, click on the Add button under the song you selected. Click Add Song To Profile if prompted whether its the song you want to add.
Hi dear.
Thanks for asking the question.
I have a good answer in this regard.
In one minutes you can add songs with few clicks.when you will click any song of your choice you will get very hurry.
you can chose the song from here very easily.and you also share with your friends just share that song when you
Add songs to my space.first login you are my space profile.
And then click on the link which i am giving you.and just say edit profile.
https://www.lifewire.com/sign-up-for-the-new-myspace-step-by-step-tutorial-2654937
I hope you will like it.
