I want to know more about astaro vpn linux client.
Hello guys,
I want to know more about an Astaro VPN Linux client. I heard that this will help manage and offer an easy way for mobile workers to work online using a VPN client and I want to try this one but I don’t know all the requirements needed before the process will push through. Thank you.
Best Answer by Goram Ian
Answered By 60 points N/A #174134
Hi Brenda Lopez,
As of this moment, the link that I attached below could be the best solution for your concern. It has a lot of information about Astaro VPN Linux Client.
ASTARO: Features
You may also join the discussion on this site:
ASTARO: VPN Client for Linux
The PDF File below would also helpful:
http://www.roundrobintech.com/404
Answered By 0 points N/A #174135
Hello Brenda,
As all stuff on Linux, Astaro is no exception when it comes to easiness and lightness. Astaro is flexible and it allows you authentication methods like certificates, usernames and passwords. I posted below a link where you can find all information you need.
https://openvpn.net/index.php/open-source/documentation/howto.html
Best regards.
