Hello Guys,
I want to know more about intel WiFi manager alternative.
What is the best feature of this kind of software, advantages and disadvantages?
And I want to know all the requirements needed for the installation and the downloading process.
I hope you can give me some information.
Thank you.
I want to know more about intel wifi manager alternative
Two main reasons are that the undertakings are fitted in WIFi: they need to be mobile (whether for employees, customers or because of devices that are not equipped with RJ45 plug, such as smartphones and tablets) and free installation of RJ45 jacks in buildings or wiring between buildings.
In the latter case, in fact, it is often much cheaper to connect two or more WiFi buildings separated by hundreds of meters by installing a network cable connection (+ switches) or optical fiber.
Simply place an access point configured point to point (with a unidirectional antenna) on the roof to create hundreds of meters of the cable network from the origin, and in another building, an extension of the network.
Additional internet will not work without a connection between buildings. Place an access point by a building and it should work. One constraint: there must be no obstructions between the two connected access points. Ideally, they should be placed as high as possible.
Points to access modern multi-radio reach a theoretical speed of 900 Mbps.
As the device is build in and require special software to perform its functions.
You can also use other software’s like easy wife radar to check the assess points near your location to access them and there are much more software’s to help you in this way.
Smith Thompson
