Because of the untrustworthy power supply in most of the countries, the use of power banks has become the order of the day. Due to these activities I would like to know if there are any drawbacks in the use of power banks for Smart phone and laptops. And to what extent the power banks influence the performance of smart phone and laptops?
I want to know more about Power Banks
Power banks battery comes with two types of battery.
1. Lithium Ion
2. Lithium Polymer
Lithium Polymer battery comes with plastic casing, light weight and more safe, but it is lit bit expensive. Whereas Lithium Ion is the old one comes in most of the power banks, and it is cheap.
As you want a more safely operational power bank, you can choose lithium polymer battery.
Next thing you should be checking the current rating of your device and you should buy a matching one only.
Then is the battery capacity, as the capacity increases the size of the battery also increases and the battery life also extends.
You can read more from here or here
