Hello, experts! I am using android apps in iPhone 5. I have heard from people that secure deletion Android software is needed for removal of any installed software. Before using, I want to get secure deletion android review. Can anyone help me?
I want to know secure deletion android review
Hi Mercedes R David,
Thanks for the question. There are a number of secure deletion apps available for Android which helps to delete very important data permanently removed from the mobile. As they even forensic can't retrieve the data.
I am giving you a list of Apps to choose from found in the Google Android play store. In addition you will have the review of the consumer for different apps mention here in the store.
1. Secure Deletion for Android: An expensive app in its category built by Contego Laboratories can be found at this link.
2. Nuke My Phone: Another very good app for Android has a great rating from its users at a reasonable price available here.
3. Secure Erase: Hexamob presented to you one of the cheapest solution to delete confidential data permanently in this
I hope it suffices your need.
Thanks & Regards,
Hi there Mercedes R David,
Just like any other apps, it is not necessary for you to install the Secure Deletion Android as your phone will work just as usual without it, but it is still a very useful app you may want to have on your phone.
Secure Deletion Android is an Android application created to completely and permanently remove any traces of the deleted data from your phone with no options to recover the data even with the expert data recovery tools. It is simple, easy and clean app just perfect to help you keep your phone clean and tidy.
The application can easily be found via Google play on this link: https://play.google.com/store/apps/details?id=ch.secdelapp.
Best regards,
Drake Vivian
