catlin bred
60 points
Posted on - 12/07/2012
My laptop has been crashing and I have not successfully found a software that will backup and store "all" my memory data. Researching led me to Acronis. However, I want to know what program opens Acronis true images?
Hello? You can open Acornics true images using software called sync. Sync is also new to the market so take this chance and be among the few first people to try it out. You can also use it to protect all your documents that you want to be secure. This program supports disk imaging; this means you can also recover the operating system along with the files. Follow the link below https://www.acronis.com/en-us/personal/computer-backup/. I hope this solves your question.
Hello Bred,
Acronis True Image Backup as .tib files
.tib files are mainly associated with Acronis True Image by Acronis Inc.. this software creates an exact clone of the drive you want to back up and instantly restore the drive when you want.
So Only Acronis True Image Can Open .tib files
louis
Dear Catlin bred,
Acronis True Image Home is very popular and very good hard disk backup software. It supports more or less all the file of hard disk. It can create complete backup within very short time. The file which contain extension .tib are mainly opened by Acronis True Image Home. So find out the .tib file and open with Acronis True Image Home and install your backup file.
Thanks and Regards
Louis
