ripon222
10 points
Posted on - 10/31/2011
I want about the causes to get the problems of any computer.
Please help.
I want to know why the computers get problems?
Computer is very complicated machine, it has different hardware, software, drivers, which is made by different companies and developers.
There are some common reasons to get the problem of your computer. Such as hardware failure, software confection, improper drivers, out of date software or drivers, data corruption, power spike, dust and dirt, programming error, virus, malware, etc.
When you get any problem of any computer you can search ‘’computer hope’’ for the issue of all kinds problem. They help all users free of coast. And they want solve all users problems.
I wish you can solve your problems.
Thank you.
Computer is a complicated device primarily made of hardware and software. Finding the problem can be hard but if you follow some steps it should be a piece of cake.
You should be a keen observer in everything that happens in your computer, a single noise makes a difference in finding the problem. I'll give you some pointers. If your PC won't boot, you must establish how far it's getting before the problem appears.
First check the cables if it properly placed in their respective sockets. A simple solution but very effective.
Also check the power supply if it is working. Check your hard drive's health by defragment your device through the built-in defragmenter. It will check your hard drives for errors. Don't forget to update your drivers through the device manager in your control panel.
Manufacturers often updates the drivers for better performance and compatibility. Viruses can also make problems in your computer, without proper firewall and excellent anti-virus your system, these can harm your system in a way it disables some components, thus slowing your computer.
