Hi! Please let me know that What is the cable available in X-keys Kx-3? What kinds of systems are required for this? Is it copied to multiple computers? Can I get Video capture facility, microphone activation facility in X-keys Kx-3? What is the Actuation Force in X-keys Kx-3? Can X-keys Kx-3 Â be used on Macintosh computers?
Thank You
I want to know X-keys Kx-3 plus pedal
You can connect X-keys Kx-3 using the USB cable just like USB keyboard. The operating system on which it is compatible are Windows XP to windows 8, Mac OS-X 10.4 to 10.8. It also compatible with Android 4.0 and New tablets. Hence it can be used having OS which supports USB HID. It is copied to multiple computers. the actuation force is 34 to 90 oz. It can be used on Macintosh computers.
