I want to learn about how to hide program?
My brothers and cousins used to play in my laptop and computer desktop and I don’t want them to deleted important files and programs in my desktop or local disks.
Is there a way to hide programs temporarily?
If there are some way please let me know.
Thank you.
Waiting for your support.
To hide a certain program, try to hide it to a different folder and replace its name to a different name.
Remove the program icon on your desktop and from the Start menu.
Or you can simply change the icon of the program. Right-click it and then click Properties.
Another way is to put the program on a New Folder and then set the folder to Hidden.
For more information on how to hide this folder, please click on the link:
