I want to learn PHP
I want to learn PHP language and I don't know which is a best site for online learn.
Kindly suggest me about online learning site.
Hi Anonymous!
Congratulations on choosing a PHP language it is full of surprises and it won’t bore you. There are many sites that give PHP tutorials, but you have to choose the best. And nothing beats a tutorial with a hands-on video right?
So you have to do is go this site https://www.tutorialspoint.com/php/, then click the tutorials tab. Scroll down you will see Computer programming. There you will see PHP, click on it then you will some tutorials from basics to advanced PHP. It is accompanied with videos for a better learning experience.
Hope I helped you and good luck on your PHP Journey!
Alex
PHP is very simple and quick to learn language which has a very high scope in the coming time and the present time as well. Of learning PHP you should have a little knowledge about some programming basics.
But if you don't have then also its ok. You can learn them easily now as well.
I will suggest you to go to https://www.w3schools.com/php/ this is the site where you can easily learn PHP basics and then advance PHP as well I hope you will find this site much worthy and less time consuming.
All the best!
Notifications
