I want to make my pc speedy
The best solution to speeding up your computer’s performance would be to buy higher memory (DDR1, DDR2, DDR3) than what is already installed in your computer. Another trick to temporarily increase your computer’s performance would be to close any programs that are running in the background of your computer that take up a large amount of memory.
To do this you will have to open your Task Manager which can be done by pressing the Alt+Ctrl+Delete keys at the same time. Another way of accessing your task manager would be to right click on your task bar and click on Task Manager.
When you have accessed your Task Manager, navigate to the Processes tab, which can be found near the top of the application. Here is a Image of what you should be looking at.
With the Task Manager you can view all programs that are currently running on your computer.
To increase your computer’s performance simply look for which program consumes the most memory, right click on the name, and then click on end process. This process ends the program and the memory of the program that was ended will be available for use can which in turns slightly increases your computer’s performance for the time being. One thing to take note of is that you should never end programs that are listed as “SYSTEM” as they are needed for your computer to run, ending programs that are listed as “SYSTEM” may cause your computer to crash. When you have accessed your Task Manager, navigate to the Processes tab which can be found near the top of the application. Here is a Image of what you should be looking at.
HinaRabia's,
Actually, there are many things you should accomplish to make your computer speed. Here are some basic and easiest tips you can do.
Sincerely,
Rizza
You can check out your hard disk status by following these steps:
If you want to check D drive then
That shows you don’t have bad sectors in your hard disk. Now you have to perform some steps. Perform these tasks once a month regularly and you will check the speed of hard disk is really good.
For example if you have windows with user name ABC then the path of the temp folder will be like:
C:Documents and SettingsABCLocal SettingsTemp
To speed up computer's performance, you need to have high quality specifications. If you have high speed processor, RAM and other computer components installed then your computer will ran faster than what you have now. However, installing this type of hardware will cost you more than what you have. It is expensive for sure because this allows your computer to perform it's best.
Upgrade RAM, Processor up to the maximum can give your computer high speed performance. It execute command and instructions per second and fast. This is the benchmark of a computer and is ranked according to the specification of the processor. The higher the rank is, the better your computer will perform. It is advisable to install high quality hardware components. If you a gamer, video enthusiast then you'll gotto have this type of computer with higher specification.
By upgrading it at 3.06 Ghz Intel Xeon is fast and speeds up the computer in a matter of seconds.
Hard Disk also plays an important role in your PC's speed. Check your hard disk for any error and fix those.
In this techyv page, the technique is described clearly.
