I want my printer head to be installed
I have a new printer and i would want to install it.
Sadly, I'm having hard time doing it.
Can someone give me the guidelines on how to install the print head?
Thanks!
Thanks!
Connect the printer to your computer. Switch on your printer. Insert installing CD of the printer to your DVD/CD ROM drives.
An installing wizard will appear. Follow the instructions as usual to the other program installation and finally Finish it.
Print a test page. You can also go to Start button of Window.
Select Settings > Control Panel. Double click on Printer and Other Hardware. Then double click on Printers and Faxes.
From the Window of Printer and Faxes right click on the white portion of the Window and from down menu select Add Printer.
Here you will also need your printer installing CD.
The process is same as earlier.
I hope you understand it.
Thanks
Notifications
