After 3 ½ years, Nikon released the successor of D700. Nikon D800 got everyone’s attention especially by today’s multimedia photographers because it is equipped with a new Nikon-developed CMOS sensor – groundbreaking pixel count of 36.3MP CMOS sensor. It has also the Nikon’s new Expeed 3 image-processing engine and 91,000 pixels RGB sensor for speed, versatility, and high performance.
D800 has appreciably advanced feature set than its predecessor because it can provide a full cinematic experience to filmmakers and multimedia professionals. The camera is equipped with Multi-area mode Full HD D-Movie that can record at 1080p (30/25/24 frames per second) or 720p (60/50 frames per second) in AVC format.
Other specification highlights are:
• Made of rugged magnesium alloy
• Standard ISO 100-6400, expandable to ISO 50-25,600 equivalent
• 3.2”, 921000 Dot VGA TFT LCD
• Maximum frame rate for continuous shooting up to 4 fps in FX mode
• High Speed CF and SD dual memory card slots
• Two axis Virtual Horizon graphic indicators on the LCD screen and viewfinder
• 51-point AF system with 15 cross-type sensors
• Video recording up to 60 minutes, 24Mbps, with uncompressed HDMI output and audio monitoring options.
• With built in speaker and flash
• Rechargeable Lithium Ion EN-EL 15 battery
• Dimensions: Approx. 146 x 1243 x 81.5 mm
• Weight: Approx. 1000 g
Nikon D800 is recommended at the maximum retail price of INR 149,950. You may visit the Nikon D-SLR Zones spread across PAN India for an exclusive hands on experience of D800.
