jennielyn
Posted on - 10/07/2011
Hello guys,
I am Jennielyn. I am an addict user of Facebook. I am using it for over 3 years. But lately Facebook has changed its interface. I would like to know if there's a way I can get back to the old Facebook???
Can anyone here help me.
I want the old version of FaceBook
Hello Jennielyn,
Well I am afraid if you can still get back to the older version of Facebook as its too late now. But don't worry as the process is still going on to keep the old version permanent after receiving millions of requests from Facebook users.
Still, here's one technique, you can still give it a try and you might redirect to the older version of Facebook and you can then save it. On Facebook Just click on Settings on the right hand side of the webpage. Once you click on it you will get certain options. In that you'll also get an option to stay on Facebook like or go to the older version, select Go to the older version and save it and you're back to the old Facebook version.
All the best
Thanks!!
I guess, we as users will have no chance of getting the old Facebook version and features. Not unless, Facebook receives numbers of request to get an options weather user decides to use the old or new looks.
We, as users just need to adapt to the new changes of the website creator. They have this own marketing strategy to generate more income, to provide additional application and features. This is their way to market their product and to gain more popularity.
Changing to a different language, from English to UK is proven not a solution. But it's worth a try, it may work on your end but not in mine. You can still try though, it'll only cost you 2 minutes to change it.
Post a feedback, raise your concern to the management and published it to let your friends know that you are against of the new Facebook looks. But I guess, what they are after for is changing. To entice more subscriber and generate incoming and at the same time, to provide service that is easy to access. It may not work for you and favor you this time, but for sure, you will get used to it.
Go to your Account Settings, change the language you are using from English (US) to English (UK) or anything else that you would understand. You can also use the Google translate to translate the page you are using so that you would read the page in English even if it set to another language. You can also add the FACEBOOK DEVELOPERS. After that, go to Applications and close the page. Apparently they will still allow people to use the old version of Facebook if they get enough supporters of the older version.
Another technique is to go to the Settings of your Facebook page, there is an option to stay on Facebook Lite or go to the old version. Select Go to the older version and save it. If none of these work, you can just follow the tips that pop-up when you open the new Facebook layout to find out what happened and where the changes occurred.
