I want to place my picture in System property.
I saw in my friend’s computer, he placed his picture in the system property. I also want to place my picture there. How I can do so?
Hi Dear,
It is not a complicated task.
You can do it very easily. To do so, you have to create two files.
“[auto run]
Line1=Your Name
Line2=Your Address
Line3=Company Name” and save this file as “oeminfo.ini” in the same folder as above.
Now just logoff your computer and login again.
You will see that your picture is placed in system’s property.
If you want to put your picture in the System Properties, that would be easy if you are using Windows XP. Here’s how to do it. To put an image in the System Properties, you need two files: oeminfo.ini and oemlogo.bmp. You cannot just have the image file because it will not work. The other file, oeminfo.ini, must exist for the image to appear.
First, prepare the picture that you’re going to use. The image has to be 180 x 120 pixels maximum size, 256 colors, must be around 23k in size, and saved in BMP format (.bmp). Once you have the image in this format, rename it to without quotes “oemlogo.bmp”. Next, you need to create the “oeminfo.ini” file. Open Microsoft Notepad and enter the following:
[General]
Manufacturer=text
Model=text
[Support Information]
line1=”text”
line2=”text”
Replace without quotes “text” with the text you want to display. Under “[Support Information]”, make sure you enclosed the text in quotation marks. You can have as many lines as you want. Just label it correctly and in correct order like for example without quotes “line3”, “line4”, “line5”, and so on. When you are finished, save the file and name it without quotes “oeminfo.ini”.
Next, copy the “oeminfo.ini” and “oemlogo.bmp” files to “C:\WINDOWS\system32”. Once both files are copied, right-click “My Computer” and select “Properties”. You should have something like this:
Clicking on “Support Information” will display something like this:
And that’s it.
