Kyle Berry
30 points
Posted on - 11/03/2012
Hello fellows,
I want to play with full screen fifa 12. My favorite game fifa 12 helps me fight the stress at work and keeps me alive every night. I would love to play the game on a full screen mode. Can you help me change the setting of the game play mode?
Kyle Berry.
Hi Kyle Berry,
First you have to do is to change the user account settings.
1. Click on control panel>User Accounts and Family Safety>User Accounts
2. Click on Change user account control settings.
3. Drag the cursor into lowest level of the graph (Never notify lowest level) then click OK.
4. Restart the computer to apply changes.
When system successfully rebooted, do the following:
1. Open Fifa 12 folder>Game>fifasetup>fifasetup default.
Change the following:
Resolutionwith=
Resolutionheight=
Right click on your desktop and then click on Screen resolution to see the resolution you use (usually 1366X768) it’s recommended.
So change Resolutionwith=1366 and the Resolutionheight=768.
After editing, click save and now open your fifa 12. You can now play it on full screen mode.
Hope this information helps
ninearl
Kyle Berry
Here, you want to know about step by step process on how to play with fullscreen on fifa 12
INSTRUCTIONS:
1. Open the "FIFA 2012 folder or wherever you installed it.
2. Open "Game" folder.
3. Open "fifasetup" folder.
4. Open "fifasetup_default.ini" file.
5. Change "RESOLUTION = xxx RESOLUTIONHEIGHT = xxx " according to your screen resolution.
6. Save the file and start game. ENJOY 🙂
Read more click here:
Hope this will help you
Hi… here is the setting this may help you..
1. go to program files > fifa >games>fifasetup
2. look for a file "fifasetup_default.ini"
3. edit it using notepad. Just change the following settings accordingly :
RESOLUTIONWIDTH = 1280
RESOLUTIONHEIGHT = 720
ASPECTRATIO = 1.778
RENDERINGQUALITY = 3
galib
Hi, Kyle Berry.
I saw your problem .Your problem is you do not play with full screen fifa 12.Please change your game resolution .1at entry the game than go to setting. Next going to display setting than resolution setting and there is select high resolution. Your problem is solved.
Thanks,
Galib Qurishi
i think the resolution of your PC does not match with the preset resolution of FIFA-12. That's why you are facing this problem. You can follow my suggestions.
Go to the Fifa-12 folder where you installed it and open the game folder. Here, you will find a folder named fifasetup. Open it. Run the fifasetup_default.ini file. Here you will find an option to change your resolution. Change it according to your PC resolution.
Now play 🙂
