I want to play TV Channels on my computer without internet.
Hi Dear,
This is very easy to watch TV on your Computer.
You have to buy a TV Tuner card.
This card will be placed into the computer on PCI Slots.
This card will play all TV Channels.
You can capture the videos and can save it to your computer.
I hope you will enjoy a lot using this card.
Thanks
Hi Saul, if you want to watch TV Channels on your computer without using internet you will need a TV Tuner Card. TV Tuner Card is a television tuner that allows computer to received television signals. To install Tuner Card follow these steps
1st Unplug everything at the back of your PC
2nd Open the PC
3rd Touch the power supply, by that way it discharges the static electricity from your body
4th Look for an empty PCI Slot, and gently insert Tuner Card in it
5th Make sure cable connections are connected
6th Close the PC
7th Attach again the unplug cables
8th Once you have done inserting, power on the PC
9th Install the CD that came with the Card and follow the manual
10th Now you have install it . You can now watch TV Channels without internet . Hooray
