I want to protect folders with password
Hi guys ,
I want to protect my private folders with password, is their any software to do this in windows 7?
I have used pc security in windows XP, but it does not work with windows 7
Hi guys ,
Hello.
To protect folders with a password, try this software: LocK A FoLdeR.
It is very easy to download (only 0.57 MB) and very simple to install.
All you have to do is enter a "Master Password".
To lock a folder, launch LocK-A-FoLdeR and enter your "Master Password".
At the main screen press the large "Lock A Folder" button and select the folder that you want to hide and password-protect.
The folder will become invisible thus preventing access to it.
To make a folder visible again, select it from the list and press the "Unlock selected Folder" button.
Hope this is what you are looking for.
