Hi everyone,
I am using simply explained website and I want to put a logo in my profile. I don’t know much about computers, So, I want you to give me a step by step guide how to do it. so can anyone help me with that please
Thanks
I want to put a logo in my Profile it’s simple
It is very easy to upload your own picture to website. At first find out your profile in the website. Then go to change profile.In the change profile option you can find upload option. Click on the upload option. Then click on browse option. Then select your own picture. You should a copy of your photo in the documents drive. After selecting the photo click on upload option. Then you will see that the photo is uploading.Then your problem will be solved.
Just follow the steps. Go to your profile in that website which should be somewhere at the top menu bar (usually). Then there should be an option like “update profile” or “change profile”. Once you are there the spot for uploading the picture should be visible (you know it when you see it, usually at the right or left corner at the top). Around the picture find the option “upload” picture and then you just have to browse through your directories to select your picture (like you normally do in computer). Once selected, upload and you are done.
Sandara Alex
