bluendyel08
20 points
Posted on - 07/27/2011
Hi there i need to make my ms word documents private so i put a password in it,
I put that password around 3 years ago but now i forgot it.
Can you help me with my problem what should i do to be able to recover my lost password i cannot open the document now?
I want to recover my password on my ms word document
What you need to do is
Download a Petri-recommended office password pro utility
Now start the password recovery wizard
Use the Open command on the toolbar (or in the application’s file menu) and locate the Word document you’d like to access. This launches the Office Password Recovery wizard.
Choose to Remove or Retrieve the Password Office Password Recovery gives you two ways of accessing your protected file; completely remove the password protection, or reveal the original password. Choose the best option that meets your needs
Now delete the existing password, the application gathers some data , provide that data and determine the ideal configuration needed to remove your password.
As this process completes just click OK
I think this will help you to recover your password
To recover your Word document password, you'll need to first download the Petri-recommended Office Password Recovery Pro utility.
Click at open option.
The wizard then asks you to open the password contain file, which you want to  open.
Choose the 2ndoption (Recover the password to open),
If you don’t’ have any clues to go on, simply leave the default selections as they are and press the Next button thrice and then click Finish.
Office Password Recovery will begin trying millions of combinations to bypass the password on your file. This process will continue in the background, using a number of different password attack schemes until it locates a match
   7 .Once your password has been recovered, the program clearly notifies you of its success and the results:
  9. Copy the recovered password and paste or rewrite in the required field to open the password file.
Asad Naeem
To resolve this issue you can apply another techniques too. Pay a visit this Techyv post to get more procedure.
Recover password protected MS Word file
