I want to remove water marks from videos
I have some videos files which have water marks on it. I want to remove that for some officail uses.
I want some one to suggest a software for me. And how to use that software to remove water marks on the video.
Have a nice day
Answered By 0 points N/A #135159
Hello Olivia welcome to techyv.com in your case are this watermarks is made up of a application that are not license? If yes then you should get a license of this so you can create a video file that are not marked with watermarks. The other way is just to minimize only the opacity of watermarks by playing it in the vlc player it is a free software that you can download it by searching it on the google and then just adjust the brightness and contrast until you do feel more comfortable to watch it.There is no way or software as of now that can remove video watermarks it’s because it is already in the video timeline maybe there is a chance but not 100% sure if you are an expert of adobe after effects.
Answered By 590495 points N/A #326102
Unfortunately, you cannot do that. There is no software that can remove video watermarks or designed to remove watermarks on videos. When someone creates a video with embedded watermark, that watermark is permanent. This often happens when you create or edit a video using a demo version of a video editing software.
This is to remind you that you are using an unlicensed version and also so you can’t use the output video for commercial use. If you intend to remove the watermark on the video, one workaround is to cut the side of the video where the watermark is located.
Another way is to hide it using another image or your logo or blur it like when censoring a portion of a video. That’s the best remedy you can do.
