I want to repair the Norton which is installed in my system.
I want to repair the Norton which is installed in my system, but I cannot remove it from the control panel. What can I do? Please help me!
Go to start – run – type regedit and press enter. A window will open. Then press ctrl+f, type the "Norton" and press enter. Let the window find the registry. If found delete the registry by pressing delete button and confirming the delete by clicking yes. Then press F3 button and repeat the deleting process as described above until displayed that search item could not be found. I'm sure that after this process Norton will be removed from the control panel and then you can repair the Norton installation. Reinstall Windows if doesn't help good luck. Ask me if you want to know more.
Thanks this is great. Thanks for the information.
No problem. Just ask me if you have any problem about this?
Notifications
