Dear,
I have EVO for internet usage, I also have one laptop and one desktop PC, I want run internet through EVO at both (Laptop and desktop PC), I know this is possible please anyone can tell me its setting.
Important thing: I install window 7 at a laptop and on desktop PC I install window XP
At this time I am just using internet on my laptop but I also want internet on a desktop PC. Please tell me its setting if possible please add screenshot so I can do all steps easily.
Thanks for your time.
SHAHEEN
I want to run internet on laptop and Desktop PC through EVO
What type of EVO, you haven't mentioned. When you want a detailed solution, you have to make your question more details to solve. However, here I tell you about HTC EVO 4G and it's running process on the laptop-
You have to bring up a DOS prompt on your laptop.
Step 1. Click on your start button.
Step 2. Now click on the run application.
Step 3. Now you have to type cmd and then you have to press enter.
When the box popped up type – ipconfig
The IP address will seem appear like this- 192.168.1.10
If the IP address doesn't match, then it's not getting an IP address from your phone.
But if the IP address is OK, you have to make sure to check the Internet Sharing" box under the "Wireless & networks" section. In that case, you must have to use a USB connection between your EVO and Conputer/laptop.
For more instance visit here
Hope this may work.
