I want to set up a global setting for the intranet.
Hi techyv Experts,
I am back and love to be here…
I want to set up a global setting for the intranet. I don’t want each user to go to "page setup: memo style, page footer" to insert a disclaimer. The disclaimer should be present when user wants to send or reply to an email. I use Windows 2003 SBS with SP2 and exchange ser in order to send emails and receive them.
Please suggestions needed for this system.
Answered By 5 points N/A #84971
The following instructions are for configuring a test lab using a minimum number of computers. Individual computers are needed to separate the services provided on the network and to clearly show the desired functionality. This configuration is neither designed to reflect best practices nor is it designed to reflect a desired or recommended configuration for a production network. The configuration, including IP addresses and all other configuration parameters, is designed only to work on a separate test lab network.  You have to follow some instruction.. To solve your current problem, you can visit this link.
https://www.microsoft.com/en-US/download/details.aspx?id=53314
