I want a software for cleaning up an Adobe PDF document scanned
My questions is about PDF documents.
I have some in my computer, and I want to modify them a bit. One is an old book scanned, but on some pages there are stains, or they are a bit yellow and burned by a cigarette.
How can I modify the documents so they look good?
Can you please provide me with a program for cleaning up an Adobe PDF document?
I would like something easy to use because I am no expert in PC.
Answered By 0 points N/A #176621
Robert,
Most PDF editors will only let you do limited edits on your PDF (adding watermarks, resizing, consolidating pages).
You may want to check out Nitro PDF which offers file conversion features. With this, you can first convert your PDF to image files, clean them up and then convert them back to PDF.
HTH,
Wong
