I want a software to convert Microsoft word document to PDF document
Hi guys, I want your help to find a software , which need to convert Microsoft word document to PDF document , I have used Google docs for a while but it's not reliable
If you are using MS Word 2010, you don’t need a separate Word to PDF converter.
Just save the document as .pdf and you’re good!
How to save file as PDF:
1. Create your document.
2. Click File.
3. Click Save As.
4. Select PDF(*.pdf) from the drop down menu of Save as type.
5. Select Standard and uncheck Open file after publishing.
6. Click Save.
If you are using MS Word 2007, you’ll be needing an Add-in that can be downloaded from Microsoft.
This would allow you to save document as PDF the way you save it using MS Word 2010.
If you are using none of these, you can download and install a PDF printer such as PDFCreator.
You may also install NovaPDF, which can be downloaded here, to convert your Word document to PDF file.
I have used a couple of free software's to help me convert Microsoft Word Document to PDF document, but most of them did not give the exact output that I need. Some did left a white horizontal line between texts and characters, maybe it is because they are free. Now, I am using an online PDF converter I found through Google. This is the link:
I have tried this and have used it in all of my .doc files that need to be converted to PDF and I can say that it is very reliable. You just need to upload your file and click the browse button. The output will be given in no time. Plus, no more lines in between characters!
However, if online converter is a no-no for you, you may want to try Sub Systems doc to PDF converter which has a lot of great features that you cannot find in free software's.
