I want a solution of my sound care driver for win7
I want a solution of my sound care driver. My care is CREATIVE SOUND BLASTER LIVE!. I'm running win7 on my PC right now but there is no support file to install my care. How do I solve this problem.
Please click on this link for the Windows 7 compatible driver for Creative Sound Blaster Live! Scroll down to the Drivers Portion, look for Creative Sound Blaster audio driver 1.04.0090 then click on “Show Details” which is on the right side. You may also check the screenshot below for the details.
If you have not tried this driver yet, download the file by clicking this link and click on “Agree” at the bottom, after reading the Terms of Agreement. Save the file to your computer and save the progress on any file you might be working on, then close all your open applications.
If you have any drivers installed, uninstall it first and restart the computer.
Double click on the file you have just downloaded and follow the instructions on its installation wizard.
I hope this will help you install your sound card.
