I want some details about the new Asus Transformer Pad. Some technical details like :
Does its screen a outside friendly nature when we use it ?
Is it have a official GPS feature ?
And also I want its measures like thickness, weight, etc …
Hope some one will give me a reply.
erlcat
I want some details about Asus Transformer Pad
ASUS TRANSFORMER PAD TF300
-The screen size is 10.1 inches and has 350 nits of brightness, body width is .38 inches (9.7 mm) , weight scales at 1.39 pounds and it is slimmer but heavier compared to 1.29 pounds Galaxy Tab 2 10.1. (It is not outside friendly compare to Prime's but gives high level of performance like the GPS and WiFi do not encounter problems)
-Body is made of plastic not metal like the Prime's.
–Bluetooth 3.0, a gyroscope, e-compass, aGPS, an ambient light sensor and a G-sensor, with either 16GB or 32GB of internal storage
-Has 8-megapixel auto-focusing camera, paired with a 1.2-megapixel one on the front
-Battery life up to 12 hours
