Help on making 3D Animated Videos
I need someone to learn me how to do 3D animation videos and how to use AutoCAD 3D and 2D please quickly just give me the basic steps and the programs that i should download so please anyone know how and without any errors please just tell me
Best Answer by Jamesmarshall
Answered By 0 points N/A #97498
Yes. That's a major problem among many of the individuals. There are many video tutorials and eBook that can help you learn AutoCAD drawing, but their cost lets you fall back. Instead you could search for some free eBook on www.freebookspot.be. There are many eBook under the AutoCAD category that will fit your needs.
If the only thing, you need is video tutorials, then there are many commercial tutorials, that you can download. I think the whole Lynda series is a great way to start your AutoCAD drawings. CBT nuggets are also some of the famous ones in this field. You could search piratebay.org for these free AutoCAD tutorials.
First, download AutoCAD and install it , so that you can practice it along with the videos. You could also explore AutoCAD , so that you could easily get in touch with it.
There are separate sites dedicated only to teach AutoCAD. Some of them are:
www.we-r-here.com
www.cadtutor.com
www.autocadmark.com
These are some of the sites where you can find many number of tutorials that will help you excel in Autocad.
Cheers.
Answered By 5 points N/A #97499
There are lots of software you can download to create a 2D or 3D animation. If you can select the adobe flash or even swishmax that can gave you tutorial manuals and free license in a couple of weeks.
You can search it easily using google.com. Simple 3D and 2D animations are created like a flying object or moving object using this applications. Other applications that may be useful is Photoshop and illustrator that can give you different template and design.
Hope it helps.
Dlanear-
