I want to stop driver signing
Hi, my pc is installed with windows vista.
Can any one help me to stop driver signing?
Thanks in advance.
Thanks in advance.
Hey Chadley maya!
If you want to disable the Driver Signing then you do not need to worry about this.
It is very simple procedure you can do this in few steps. So for this purpose what you need to do is just to follow these steps.
1. Click on Start Button and Select Run.
2. In the Run Box, type cmd and press enter.
3. It will open Command Prompt.
4. In the Command Prompt you have to type the following command
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS. After typing this command you have to press enter.
Once the process is complete you will be succeeded in disabling the Driver Signing.
Thanks
I thought you are referring to a different driver signing task in Windows Vista while what you mean is the digital driver signing that is being enforced in the operating system. This doesn’t only happen in Windows Vista but in Windows XP as well and other later editions of Microsoft Windows. Here’s how you can turn off or disable the digital driver signing check in Windows Vista. This should be done using an administrator account or an account that has administrative privileges.
After that restart your computer and then install the unsigned driver of your device. On the other hand, if after the installation you want to enable the digital driver signing check again, repeat the steps above and then use this command instead and then hit Enter: “Bcdedit.exe /set nointegritychecks Off”. Restart your computer after that and you are now back to normal.
