Planning to buy a tiny android computer and I don't have any idea how much it costs in websites.
Can you tell me how much it costs and where can I buy some?
I need the best solution for my problem, and I need it asap. give me some links too, any android users here?
Can give me a solution.
I want a tiny android , how much it costs now?
Hello.
After going through the internet I found an android pc with best features.
It is a NEW 7 inch android 4.0 Capacitive Screen 512M 4GB Camera WIFI all winner a13 tablet pc
It has all the features including 7 inch android 4.0 Capacitive Screen ,512Mb ram  4GB hard disk Camera WIFI.
Its price ranges from $53.99 to  63.49
For other details and to buy this product click on the link.
Thank you.
I would strongly recommend the Android Mini PC RK3066. Its price ranges from $50-$60.
Here are its technical specifications:
Running in Android 4.1 Jelly bean
Its CPU is Dual core, 1.6GHZ Cortex A9
With 1 GB RAM
It has 4 GB built-in flash
The display resolution is 1280×720
But I can say that its notable feature is its Bluetooth radio that allows the user for expansion. You can also use it in video calling and OS includes Google Now. Though it is tiny, it strong enough for you to play 3D games and watch movies.
Below are the links where you can buy it:
https://www.amazon.com/Android-RK3066-Bluetooth-headphone-standard/dp/B00AZR1TG2
https://www.laptopmag.com/reviews/mini-pcs/android-mini-pc-rk3066
