I Want To Download The ACM Driver For My Computer
The CDC ACM+ Linux gadget MS driver is a USB composite gadget driver that implements serial communication and mass storage functions. The driver allows the device to be registered on a host computer as a serial port and a USB thumb drive.
The user needs to follow the described steps to download the ACM driver on the computer:
Step 1: Open the browser and visit this website.
Step 2: Go to the Driver section from the menu.
Step 3: Search for the ACM driver and wait for the search to end.
Step 4: Now, the result will show CDC Abstract Control Model (ACM) Installer.
Step 5: Look for the latest file version, and the size of the file will be 23.43 MB.
The user needs to check that the file supports which operating system will be given in the result.
Step 6: Download the file and install the driver after downloading it.
