I Want To Know About The Situations That Cause Acpi Bios Errors In The System
Mention the situations that cause Acpi bios errors in the system. What is the cause behind the occurrence of the error?
When the user is installing Windows 10 or other OS when the PC is resuming after a long time of hibernation, when the user is booting the PC and encounter a restart loop, or working with the different brands of PC’s are the situations in which Acpi bios error appear on the screen.
There are two reasons behind the occurrence of the error:
• Advanced Configuration and Power Interface Basic Input / Output System is not compliant with ACPI prompts the error messages.
• The user has added the RAM to the computer during hibernation; the OS will detect this change while the file Hiberfil. sys is loaded.
The solution to fix the Acpi bios error code is as follows:
Solution 1: Fix the system
Step 1: Open the command prompt and run as administrator.
Step 2: Type “DISM.exe/Online/Cleanup-image/Restorehealth.”
Step 3: Insert media and type “DISM.exe/Online/Cleanup-image/Restorehealth/Source:C:RepairSourceWindows/LimitAccess.”
Solution 2: Update the driver
Solution 3: Restore the system
Step 1: Restart the system.
Step 2: Hold the F8 button to see the operating system choice.
Step 3: Choose ‘Last Known Good Configuration’ from the Windows Advanced options.
