I Want To Learn About Disk Error Checking Windows 7
Hi, I’m a non-IT person using a laptop with Windows 7. I want to learn about the Disk Error Checking Windows 7. Please tell me about the Disk Error Checking Windows 7 ASAP. Thanks in advance.
Follow the given steps for Disk Error Checking Windows 7:
1) Firstly, after clicking on the Start Windows icon, click on Open Windows Explorer.
2) Then, select Computer, in the navigation pane, for appearing your drives in the right pane.
3) Now, select the drive that you want to check. Then, click on Properties.
4) After clicking on the Tools, select the button of Check now.
5) Then, In the Check Disk window, select the “automatically fix file system errors” checkbox. After that, click Start.
6) Now, if the drive that you want to check is currently in use, then you will see a dialog box (with a warning message). Click Schedule disk check, if this happens.
7) After exiting all open programs, restart your computer.
8) The checking starts immediately. The results will be displayed after it is completed.
