I Want To Print My Documents, But I Face A 0x00000eb Error Message
What is the 0x00000eb error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
When the printers drivers are corrupted, or the cables are not properly connected, then the error occurs, which is known as 0x00000eb error. Corrupted or incompatible printers drivers are the main reason behind the occurrence of this error.
The steps to fix 0x00000eb error are as follows:
• Check Windows Installer Service.
1. Hold Windows Key and press R to open the Run dialog box.
2. Type services.MSC and click on OK.
3. Now, a list will open. Locate Windows Installer and start it.
4. Restart your computer.
• Remove old drivers and re-install them.
1. Open “Devices & Printers”
2. Click on Print Server Properties from the top.
3. Locate the driver of your printer by clicking on the Drivers tab. Remove it.
• Delete the printer’s key.
Now, reinstall the driver and check it will work.
