I Want To Replace My Acer Extensa 4420 Motherboards
Acer Extensa 4420 motherboards are also referred to as Acer Extensa Mainboard, System Board, Planar Board, Logic Board, and Circuit Board.
The steps to replace the Acer Extensa 4420 motherboards are as follows:
Step 1: Turn the laptop over and remove the screws of the back panel.
Step 2: Remove the cover and eject the hard drive.
Step 3: Remove the optical drive of the laptop.
Step 4: Turn the laptop over and open it.
Step 5: Remove the laptop keyboard and disconnect the cable of the keyboard.
Step 6: Remove the screws and disconnect the cable.
Step 7: Now, remove the touchpad, then remove the laptop fan.
Step 8: Now, it’s time to remove the motherboard and disconnects its cable.
Step 9: Remove the CPU from the motherboard and after that, attach everything back in order.
Now, your motherboard is replaced or repaired. Use your system wisely.
