I Want To Upgrade My Acer Nitro SSD For Gaming Purposes
Explain each step to upgrade my Acer nitro SSD and attach a snapshot of the process to make it convenient?
The user needs to follow some basic steps to upgrade the SSD on my Acer nitro laptop:
Step 1: Rotate your laptop and use a Philips-head screwdriver, then unscrew the fasteners holding the two easy-access panels in place.
Step 2: Remove the panel with the finger.
Step 3: Unscrew the four fasteners holding the 2.5-inch SSD mount in place.
Step 4: Unscrew the 15-fastener holding the plastic back panel of the laptop.
Step 5: Carefully remove the back panel.
Step 6: Unscrew the fastener at the end of the SSD section.
Step 7: Insert the new M.2 SSD into the slot, keeping the flat side aside.
Step 8: Screwback the fastener at the end of the M.2 SSD section.
Step 9: Replace the back panel with some force and screw back the 15-fastener.
Step 10: Put back the panel carefully and put back the screw.
