I want to update 3g USB driver on android tablet
Hi All,
I am using 3G Galaxy Tab P7500 which is running Android 4.0.I want to update 3g usb driver on android tablet for modems. Is it possible? How can I do it?
Hi All,
Hi Aubrielillian,
 I did not hear about updating USB drivers for 3G modems. Simply, there are no benefits in doing so. You just connect your USB device to your Galaxy Tab and you're good to go. It should simply work like that.
 If you want, you can update your tablet's firmware through PC software called "Kies". Just install it, restart your PC and connect your Galaxy Tab to PC. Launch "Kies" and there should be a notification about tablet firmware update, if there's any.
I hope my answer will clear your doubts.
