anonymous
7060 points
Posted on - 08/05/2011
I have a computer. Now I want to use internet by my Nokia N70 mobile.
Is it possible or not . If possible describe which software and hardware will be need.
And how can I set up the software or hardware ?
lincon
Hello Mamun,
I have a solution for you. To connect to internet in computer 1st you should make sure that internet is on in your cell phone.
You must have got a CD when you bought your cell phone. Now follow this simple steps written below.
1. Install Nokia PC suit from that CD.
2. connect your cell phone to your computer via USB.
3. select PC suit option in your cell phone.
4. Open Nokia pc suit in your computer
5. Go to one touch access wizard(shown in red circle) and process it. Now you can use internet in your computer.
I hope this will help you
lincon
If you want to use internet through your Nokia N70, at first make sure you have internet connection on your phone. Now connect your phone with your computer using USB DATA CABLE and set your phone to “use as modem”. Your phone will connect automatically when you start browsing.
You can also use your N70 as a “Bluetooth modem”. To use like this you have to connect your mobile with your computer through Bluetooth.
Then select “Control panel”, then “Phone and Modem options”, now choose “Modem Bluetooth” and “search for Modem”.
Once your phone is detected, you can use it as a Modem.
