Mia Molly
20 points
Posted on - 01/29/2013
Hi Programmers,
I am newbie in programming. I have to make a code for a simple project, but I am quite familiar with coding. I have to take the pictures using my webcam. I am searching for webcam image capture sample code. Please give me Visual basic C# code for this project. The code should me easy and understand able.
I want webcam image capture sample code for C#.
Hi Mia,
I used this method once. Dynamsoft allows you to integrate Dynamic Webcam SDK. Download from the below link:
https://www.dynamsoft.com/Products/Products.aspx
Then to initialize Dynamic Webcam SDK to capture images from webcam use the code:
After creating the controls, you can capture images and documents from your devices. Then check the sample codes in attached Code file 2 which will show you how to acquire images.
