jhonny jack
30 points
Posted on - 11/28/2012
Hello People,
I wanted to get some files formatted through QuarkXPress (R) and failed to receive an error message. It is showing the problem with the resolution. I want to know elaborate description in respect of the problem.
If you know, please let me know in details.
Thanks for the support.
QuarkXPress (R)
One or more of the select picture has a resolution lower than 91 dpi and is limited to a low-resolution display. [10109]
Hello Jhonny Jack,
This QuarkXpress error emphasis that the picture or image you are trying to import in the lower resolution case the programs renderer can handle and that is lower than 91 DPI so, the picture or image is more than 91 DPI, first you need to edit the image in any image editing software. Well Photoshop is the best editor for this purpose, you can easily change it according to the specified DPI requirements by using Adobe Photoshop.
