I wanted to load some translators using Adobe Dreamweaver
Good day everyone,
I wanted to load some translators using Adobe Dreamweaver.
Instead of loading them, it just gives me these long irritable errors.
The following translators were not loaded due to errors:
ICEregions.htm: has configuration information that is invalid.
jQueryMobile.htm: has configuration information that is invalid.
XSLT Transform.htm: has configuration information that is invalid.
This is just one of the many errors that this program is giving me.
I need your help on this one.
Thank you very much to whoever can give me some ways to fix this.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #159447
Hi Hamilton Honny
Many Dreamweaver “Loading Translator”  errors are caused due to their file cache system.
There are multiple methods to solve your problem.
Method 1
  1. You have to reset you workspace layout that can solve many of your small problems.
  2. Do this < C:\windows\workspace layout\[RESET “Current workspace Name”] >.
If your problem is not yet solved then we have another method to solve this problem.
Method 2
  1. You have to go to into windows application data folder.
  2. Go there < C:\Users\[Current user]\AppData\Roaming >.
  3. Or go to window menu and click on Run now type “%appdata%” and press enter.
  4. Now you are in your app folder, you have to Navigate to its configuration file.
  5. As in my system it’s Adobe\DreamWeaverCS6\en_US\Configuration.
  6. You have to find “winfilecache*.dat” files and remove/delete them.
  7. Maybe you have more than one configuration directory in Adobe Dreamweaver.
  8. Go to both folders and delete “winfilecache*.dat” files from there.
  9. Restart your Dreamweaver and enjoy coding again.
It’ll surely help you a lot. Good Luck!
Johnstoon Leen
Answered By 0 points N/A #159448
Sometimes translators were not loaded due to the errors: xslt.htm has invalid configuration information.
This means the javaScript isn't getting along with itself or your system.
WHAT TO DO:
1. Go to main drive
2. Go to your user folder > library > application support
Then find the Dreamweaver folder(Make sure Dreamweaver is Not running)rename” configuration’’
“configuration – old.” Restart Dreamweaver.This should clear up the problem.
Another way could be:
Go to Windows Start menu > Run > type: %appdata% and hit enter.
Find theWinFileCache*.dat file(s) and delete them.. If you have more than one Configuration folder (I have "Configuration" and "Configuration-1") go into each one of those and delete WinFileCache*.dats.
You can start coding again.
