Hello fellows,
I would like to ask if how to remove tags on pdfs? Pdf files are very useful nowadays specially when making business reports. I was assigned to edit some pdf report for this month and some pdf file has tags. Do you have idea on removing tags on pdf forms? I need your assistance. Thanks.
Chloe Chylly.
I would like to ask if how to remove tags on PDFs?
To remove the tags from your reports you have to use Adobe Acrobat because the PDF file created on it. There is a simple and easy way to remove the tags. Just follow these steps to remove tags from your PDF.
1. Open the PDF file from which you want to remove tags
2. Now click on the view button which will be on the top of the window in the menu bar.
3. In view select the navigation panels and then the tags.
4. Now click on the option and select over there delete tags and click on ok. The tag will be removed from your PDF.
