I would like to convert fax viewer to adobe reader
Hallo, Guys! I bought a new computer with windows 7 pre-installed. I realize that there was no fax viewer and I checked around and got it for free. However, I would like to convert fax viewer to adobe reader for my presentations. I have tried several ways but I can seem to figure it out. How do I go about it and is there a better application to handle both? Thanks.
Best Answer by Duncan Courtright
Answered By 35 points N/A #164545
Hello Wallace,
You can't go wrong with adobe reader it simply is the best. Just completely uninstall fax viewer and install this.
Let it update then you are good to go. I hope I have resolved your issue.
If you have any other questions please feel free to ask.
Sincerely,
Luz M Terry
Answered By 0 points N/A #164546
There's a tool which can both view fax messages and convert them to pdf and a few other file formats. The only downside is that you'll need to buy it. It costs $29.99. But they do offer the option of downloading a free trial to evaluate the software to see if it answers your needs before you make the commitment to buy the software: You can download the Pcx-Dcx Fax Viewer 13.05.01 from http://www.softpedia.com/get/Office-tools/Other-Office-Tools/Pcx-Dcx-Fax-Viewer.shtml#download I'm sure this will solve your problem.
