I would like to know about my machine’s windows Intel system
Hello experts, I am using windows XP on my computer. I would like to know about my machine’s windows Intel system. Where I can find this system in my windows?
Hi Jelma, if you are talking about your windows configuration than its easy to know. Right click on your my computer. Select properties. Now you can see your whole system configuration. If this is not the subject than I didn't understand your question. Please make clear to get your solution. Thank you.
Hi Jelma Demo,
I hope you want to know all about your Windows XP system. You can do this by typing the following command in RUN. Type “dxdiag” in RUN and press Enter. It will show a dialog box with Yes and No buttons. Press Yes here. It will show you a summary of your computer, with all of the information about hardware and software. Thanks.
Dear Jelma,
All windows that Microsoft Company has developed, has many utilities that can show the summary of your computer.
That shows you all hardware attached to your computer.
1. Type “dxdiag” in RUN menu then press ok. It will open a DirectX Diagnostic Tool.
Just like this window.
1. Other method to see your system information. Type “devmgmt.msc” and press enter. This command will open Device Manager.
You can see all the hardware in this section.
Hope it help.
Regards
