Ialmrnt5 Display Driver has Stopped Working
When I downloaded the Sims 2 for the first time, I was able to use it just fine. After some time, the game will freeze and showed a display driver error and ialmrnt5 has stopped working normally. I tried to reboot but still faced the same faulty message. Can anyone help me on this? Thank you.
Windows – Display Driver Stopped Responding
The ialmrnt5 display driver has stopped working normally. Save your work and reboot the system to restore full display functionality. The next time you reboot the machine a dialog will be displayed giving you a chance to upload data about this failure to Microsoft.
Answered By 80 points N/A #160670
I'm sorry to hear your problem. I have encountered that kind of problem before and it really sucks. I hope that my solution will also help you solve your issue. Easy. i Too had this problem. I searched for hours and finally came across a post… All you need to do is update your Graphics Card's driver.
To do this you will have to go to your manufacturer's site…(for this part your on your own). Simply Search for your card and they should have a easily executable file to download & install the drivers. Mine was Intel/ https://downloadcenter.intel.com/. Good luck and don't hesitate to consult me if you have anymore questions about your problem.
Thank you so much.
Zrian
