Germain
Posted on - 10/26/2011
Greetings to all at TechyV!
I'm researching system errors together with a friend for a subject paper. Can anybody kindly tell me if they have encountered this error before and what have they done to resolve it – system change, repair tools, anything that fixed it.
Thanks for all ideas shared.
I appreciate your help!
IA&P error message
Current method; mod_Delete_User
 Exception message: Incorrect syntax near ‘tblUsers’.
 OK
IA&P Error Message Incorrect Syntax
You just simply check if there is any file that deleted or maybe there are files that are corrupted form your application just simply check on that and then try to download the tune up utilities and then install that to your machine to fix the files from the system and then to repair any errors that can be found the tune up utilities from your system and then simply just download another software like the error repair tool and then just install that to your machine then start scanning after that you just simply repair the found errors to your machine just simply try that one.
Ben
