iAtkos ML unable to initialize the GPU test
Hello folks,
I am getting error and it makes me tired. I am not getting this error down. I installed iAtkos ML on my system and installation is perfect I did it with all default options. Just I change the graphics card setting to support video. But I don’t understand the cause of the error? Totally blank help please.
ERROR: Unable to initialize the GPU test.
See the log file for details.
Bye…
Answered By 590495 points N/A #178355
The program is having a hard time initializing or starting the GPU test. GPU stands for Graphics Processing Unit and when you see it anywhere on your computer, it refers to the video card. If a computer has a CPU or the Central Processing Unit, this is its equivalent in video card but not all video cards have GPU. A built-in video card that has only 32 MB video RAM doesn’t have a GPU.
Also, try updating the video card’s driver to better assess the application in testing the graphics processing unit of the video card. Open your web browser and visit the official website of your device. You should also make sure you meet all the requirements when you installed iATKOS. If you installed iATKOS ML2, you need a compatible motherboard, an Intel Core 2 Duo processor or newer 64-bit CPU, 1 GB RAM minimum, 15 GB free space, and a compatible video card.
