IBM Connection file and profile component included in Lotus Note and Domino?
We all know about IBM also there services & products.
They also have Lotus Note and Domino.
Is it included IBM Connection files and profiles component in Lotus Note and Domino?
How it helps to a client becomes a social business?
Is it good for any small type of business?
Answered By 0 points N/A #97189
Answer for first part: Yes profile is a  part of Lotus and Domino. It helps you to integrate directory to location engine,also helps  you identify and work with key people who have specific knowledge or strategic business relationships. Profile help you find the people you need so fast by searching across your organization using tags to make it much easy.
You can specific how to search for people based on qualities such as the personal name or the organization name location and interests.
With IBM connection profile you can do many things like :
1. Tap into the knowledge capital within your organization.
2. Easily establish new business contacts.and expand your personal network.
3. Develop and maintain personal relationships.
Answer for second part about how it helps the client to become a social business.it make it easy for the client to access to provide convenient from the notes sidebar and integrate collaboration especially email.
Answer for Third part about how its good for small business. its helps you get your work done quickly and providing you with a single point of access to help create ,discover and share knowledge, contacts with team so easily. Lotus Notes helps connect you to people across the world.
I hope this will help you start your business fast which you all luck if you want to know more I think this link will help you out.
http://www-01.ibm.com/software/lotus/notesanddomino/clientlicensing.html
